Activity Forums Adobe After Effects Inexplicable Colour Change from AE Quicktime Render to AE Import…
  • Inexplicable Colour Change from AE Quicktime Render to AE Import…
    Posted by Benjamin Field on June 13, 2014 at 9:34 am
    Hi All,
    Using AE CS6 and I’m completely stumped by this one…
    I exported a Trapcode Particular sequence to a Quicktime .mov with an alpha channel so I could re-import it into the main comp to speed things up.
    This is the exported clip as it appears in Quicktime:
    However, when I re-import it into AE it looks like this:
    What have I done wrong…?
    Cheers!
    Darby Edelen replied 12 years, 3 months ago 2 Members · 1 Reply
  • Darby Edelen
    June 17, 2014 at 4:00 am
    You didn’t happen to use DNxHD in a 32bpc project did you? Alas such a pairing was never meant to be. There’s a long standing problem with the way DNxHD behaves in greater than 8bpc projects.
    Even if you’re not using DNxHD, try using a different codec. If you need an alpha I’d recommend rendering to an image sequence unless that’s out of the question.
    Darby Edelen
