Activity Forums Adobe After Effects Expressions Inertial text Animator, Animate off at out outpoint
  • Inertial text Animator, Animate off at out outpoint
    Posted by Donavon Brutus on July 8, 2024 at 5:18 pm
    I have the expression below that automatically animates text on using whatever parameters you set at the layer inpoint. How do you alter the expression to make the text also reverse the same animation at the outpoint of the layer?
    freq = .25;
    decay = 20;
    delay = .05;
    dur = .15;
    myDelay = (textIndex-1)*delay;
    t = time – (inPoint + myDelay);
    startVal = 100;
    endVal = 0;
    if(t < dur){ linear(t,0,dur,startVal,endVal); }else{ amp = (endVal – startVal)/dur; w = freq*Math.PI*2; endVal + amp*(Math.sin(t*w)/Math.exp(decay*t)/w); }
    Donavon Brutus replied 2 years, 1 month ago 2 Members · 2 Replies
  • Dan Ebberts
    July 8, 2024 at 7:20 pm
    See if this gets you close:
    freq = .25;
    decay = 20;
    delay = .05;
    dur = .15;
    if (time < (inPoint+outPoint)/2){
    t = time - (inPoint + myDelay);
    }else{
    t = outPoint - myDelay - time+ -.1;
    startVal = 100;
    endVal = 0;
    if(t < dur){
    }else{
    amp = (endVal - startVal)/dur;
    w = freq*Math.PI*2;
  • Donavon Brutus
    July 8, 2024 at 7:27 pm
    Perfection. Thanks you so much!
