Activity Forums Adobe After Effects Expressions Inertial Bounce expressions suddenly not working!
  • Inertial Bounce expressions suddenly not working!
    Posted by Michael Chappell on August 15, 2013 at 8:37 pm
    Can anyone tell me why this started happening in CS6? This expression always worked before.
    One theory was that the comp was too long (18 minutes). I have this in a 3 minute comp now and still get the same error. (I have used this expression in 2-3 minute comps before and not had issues.)
    Also received this reply:
    Not sure how to implement that, though.
    Also, the expression doesn’t break right away. It works for about 30 seconds before throwing an error.
    Here’s a link to the comp: https://www.dropbox.com/s/6nktob8yj8uohoi/007%20Sample%20Comp.aep
    Mike
    amp = .1;
    freq = 2.0;
    decay = 6.0;
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n--;
    if (n == 0){ t = 0;
    }else{
    t = time - key(n).time;
    if (n > 0){
    v = velocityAtTime(key(n).time - thisComp.frameDuration/10);
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{value}
    Roger Maus replied 12 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    August 15, 2013 at 9:39 pm
    Try it this way:
    decay = 6.0;
    n = 0;
    if (numKeys > 0){
    n--;
    if (n == 0){ t = 0;
    }else{
    if (n > 0){
    if (t < 2)
    else
    value;
    }else{value}
    Dan
  • Michael Chappell
    August 15, 2013 at 10:52 pm
    That did it!
    Thanks so much, Dan!
    Best,
    Mike
  • Ridley Walker
    August 16, 2013 at 12:57 am
    @Dan;
    Could you elaborate on the issue with the original expression and how replacement you graciously provided solves the problem?
  • Dan Ebberts
    August 16, 2013 at 1:14 am
    After a couple of minutes or so, Math.exp(decay*t) will become such a huge number that JavaScript represents it as “Infinity”, which I’m guessing breaks the division operation. I just limited the calculation to a couple of seconds, which is all it really needs for the decay to finish.
    Dan
  • Roger Maus
    November 25, 2013 at 10:35 am
    Hi there,
    sorry for picking over these bones, but
    what could be the reason if the bouncing aborts – like in my case?
    I applied the expression to the position property.
    amp = 0.1
    freq = 1.0
    decay = 2.2
  • Dan Ebberts
    November 25, 2013 at 2:34 pm
    It looks like you’re using the version of the expression that cuts off after a couple of seconds to keep from generating a divide by zero error. You could go back, to the original expression, or increase the cut off from 2 to 10 or so, or use this version, which I like better:
    https://www.motionscript.com/articles/bounce-and-overshoot.html#kf-overshoot
    Dan
  • Roger Maus
    November 25, 2013 at 5:25 pm
    Overshoot works perfectly fine. But if anyone else wants to stick to the “old” bounce expression, this is the way:
    amp = .1;
    freq = 1.5;
    decay = 2.0;
    n = 0;
    if (numKeys > 0){
    n--;
    if (n == 0){ t = 0;
    }else{
    if (n > 0 && t < 2){ //----INCREASE LATTER VALUE IF CUT OFF----//
    }else{value;
