Activity Forums Adobe After Effects Individual images to flip & form one image
  • Individual images to flip & form one image
    Posted by Didier Fereaux on January 19, 2011 at 5:58 am
    Hey guys, looked around and couldn’t find anything on it (trying to word it was difficult too).
    I’m looking at having 12 separate comps which show individual videos, all flip at separate times to form one big image.
    You know when you look in the crowds of football stadiums and everyone is holding a different sign then they flip them around and when looked at together all the pictures form one massive image like the face of someone or something, I tried doing this individually but failed…any ideas?
    Oh btw im using After Effects!
    Didier Fereaux replied 15 years, 7 months ago 3 Members · 5 Replies
  • Cory Petkovsek
    January 19, 2011 at 7:21 am
    Make the flipped version of the signs be an alpha channel. Have the face under the other comps so it shows through them.
    Cory
    Cory Petkovsek
    Corporate Video
  • Matthew Keane
    January 19, 2011 at 10:17 am
    Have you looked at the Card Dance plug-in? If you have your 12 videos together in a precomp, Card Dance will let you chop it up into sections (say a 4×3 grid) and then animate each panel separately, with your final image as the back of the panels. You can either make them flip over in sequence, like a finely-tuned North Korean propaganda show, or you can use a gradient map to make more complex transitions. As well as the rotation of each panel, you can control the scale and position, so with a wiggle expression, you should be able to make it look like a heaving crowd.
  • Matthew Keane
    January 19, 2011 at 4:25 pm
    Hi Dave,
    Ah yes, Card Wipe was the one I was thinking of – sorry about the confusion.
  • Matthew Keane
    January 19, 2011 at 5:09 pm
    Hi Dave,
    I was never too clear about the difference between those two plugins, so I just had a look. Card Wipe has a handy Transition slider, which makes it probably an easier choice than Card Dance, which seems to be all driven by gradient maps (although you can use gradient maps in Card Wipe as well).
  • Didier Fereaux
    January 21, 2011 at 12:32 am
    awesome thanks for the replies guys! Card wipe worked out perfectly! Much appreciated 🙂
