Activity Forums VEGAS Pro Indiana Jones style map travel route
  • Indiana Jones style map travel route
    Posted by Edward Vinson on August 8, 2008 at 3:27 am
    Is there a way, using Vegas Movie Studio v8, to make the red line on a map that shows the route of travel, sort of like the Indiana Jones movies?
    Edward Vinson replied 18 years ago 5 Members · 6 Replies
  • Leslie Wand
    August 8, 2008 at 7:04 am
    use a revealing wipe…..
  • Mary Waitrovich
    August 8, 2008 at 2:24 pm
    I have also had good luck with making sure project properties and render settings are all set to progressive rather than interlaced.
  • Mary Waitrovich
    August 8, 2008 at 2:29 pm
    Another way to do this is to create a series of still images of your map with the line progressing from image to image. Then in the editing tap of Preferences, set the still image length to about 1/10th of a second and add all the images. you can vary the speed of the line’s progression by varying the still image length.
    A really quick and dirty way to accomplish this is to have one image with no line and one image with your entire line on it and then use a linear wipe transition between the two.
    Mary Waitrovich
    UW-Madison
  • Charles Avanti
    August 8, 2008 at 3:58 pm
    Mary,
    Your quick and dirty idea sounds good to me.
    Charlie
  • Dan Asselin
    August 10, 2008 at 4:20 pm
    There may be some ideas you can transfer over to Vegas at this new AE tut
    https://cowcast.creativecow.net/podcast/shape-layer-tips-3-trim–237
    Just a thought because I don’t know Vegas.
  • Edward Vinson
    August 10, 2008 at 4:56 pm
    I did the swipe and it worked perfectly. Good enough for me at least. Thanks for hte ideas
