Activity Forums Adobe After Effects Expressions Index position isn’t working between comps and shapes
  • Index position isn’t working between comps and shapes
    Posted by Thomas Hannen on March 13, 2023 at 9:49 am
    I have many shapes that I want to reference to a single comp with a shape in it, in case I need to change them later on.
    The shapes are 2D and in different positions all over my canvas.
    I want to be able to position each comp using the position data from the layer above it.
    When I try to map the position data from the layer above, I get the wrong position.
    What am I doing wrong?
    As a simple example – I want to position the green star in the same place at the pentagon. The pentagon is pre-comped in a 300×300 comp, but everything is centred.
    I put this in the star’s position field:
    x = (index-1);
    y = (index-1);
    [x,y]
    And place the star layer below the pentagon layer.
    Why does the star jump to -1,-1?
    Thomas Hannen replied 3 years, 6 months ago 1 Member · 1 Reply
  • Thomas Hannen
    March 13, 2023 at 10:46 am
    ah I think i’ve got it:
    x = thisComp.layer(index-1).position[0];
    y = thisComp.layer(index-1).position[1];
    [x,y]
    (I was returning the value of the layer, not the position of that layer)
