Activity Forums Adobe After Effects Expressions index number driven by a variable?!
  • index number driven by a variable?!
    Posted by Peter Menich on May 25, 2009 at 6:19 pm
    Hey all,
    I’m trying to build a comp that looks at the layers of another comp and takes the position of a desired layer. what I have so far is this…
    temp = comp("NamesList").layer(135).transform.position.valueAtTime(0);
    x = temp[0];
    y = temp[1];
    [x,y]
    This works fine, but I wanted to add an expression control slider that drives the desired index number, like this…
    numBer = effect("layer number")("Slider");
    temp = comp("NamesList").layer(numBer).transform.position.valueAtTime(0);
    x = temp[0];
    y = temp[1];
    [x,y]
    Which doesn’t work! I get this error…
    After Effects warning: Bad Argument: Layer index 671826536 out of range
    any ideas?!
    Peter Menich replied 17 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 25, 2009 at 7:24 pm
    See if this works better:
    numBer = Math.round(effect(“layer number”)(“Slider”));
    if (numBer <= comp("NamesList").numLayers && numBer > 0){
    temp = comp(“NamesList”).layer(numBer).transform.position.valueAtTime(0);
    x = temp[0];
    y = temp[1];
    [x,y]
    }else{
    value
    Dan
  • Peter Menich
    May 26, 2009 at 8:44 am
    Mr Ebberts.
    I am, as usual, humbled.
    Works like a treat!
    Many thanks.
