Activity Forums Adobe InDesign InDesign Preflight
  • InDesign Preflight
    Posted by Jeff Cochran on May 25, 2012 at 3:26 pm
    Hello,
    I’m running a custom preflight profile in InDesign. The problem I have is, it’s flagging Adobe Illustrator files that contain only vector objects as being low resolution (72dpi). Obviously, InDesign shouldn’t be flagging the graphic at all.
    Can anyone help me fix this?
    Thanks in advance.
    Jeff
    Jeff Cochran replied 14 years, 3 months ago 2 Members · 2 Replies
  • Dwayne Smith
    May 27, 2012 at 9:59 am
    G’day Jeff
    Vector files CAN have a low resolution if you are using things like gradients or dropshadows or whatnot.
    Open the file in Illustrator and go to Effect > Document Raster Effects Settings…
    See if that fixes things
    m.
  • Jeff Cochran
    May 29, 2012 at 2:02 pm
    Hi Dwayne,
    That fixed several of the problems. It seems to be flagging a gradient that was created in Illustrator as low res. Any tips for fixing that?
    Thanks for the help. It’s greatly appreciated.
    Jeff
    Jeff Cochran
    https://www.jeffcochrandigitalartist.com/
