Activity Forums Adobe InDesign InDesign Magazine Document Setup
  • InDesign Magazine Document Setup
    Posted by Tom Sherer on January 24, 2011 at 5:05 am
    Am working on a 24-page magazine that will be saddle stitched. Been working for hours trying to get the document set up correctly, to no avail. I have a good amount of experience with InDesign, but not specifically with setting up the documents.
    The specs I have to follow are as follows:
    1. Flat Printer Spread Trim Size (Before being Trimmed): 11.625” H X 17” W
    2. Flat Printer Spread Final Trim Size: (After being trimmed): 10.75” H X 16.375” W
    3. Final Fold Size: (After being stitched): 10.75” H X 8.1875” W
    4. Head Trim: 0.375”
    5. Foot Trim: 0.5
    6. Saddle-Stitcher Lip: 0.375”
    7. Bleed: 0.125”
    8. Total Face Trim: 0.5” (1/8” Bleed + 3/8” Lip)
    In terms of the main document height and width, do I want to use the “before trim” or “after trim” numbers? Am I correct to use margins to set the head and foot trim? And I don’t get at all what the saddle-stitcher lip is. Any guidance would be appreciated.
    Thanks.
    Xavier Khonje replied 15 years, 8 months ago 2 Members · 3 Replies
  • Xavier Khonje
    January 25, 2011 at 9:25 am
    I work for a Magazine Publishing company. I would like to know which version of indesign you are using? as that might help, coz am using CS3 and some of those options are not available on mine.
  • Tom Sherer
    January 25, 2011 at 12:49 pm
    I have CS3. I’m particularly perplexed by what/where the saddle stitch lip is.
  • Xavier Khonje
    January 26, 2011 at 11:29 am
    go to FILE-PRINT BOOKLET: the Dialog box that comes has stuff about saddle stitch depending on your packaging method you might need to specify or not.
