Activity Forums Adobe After Effects InDesign into After Effects?
  • InDesign into After Effects?
    Posted by Jamie Moore on December 8, 2012 at 3:35 pm
    Hey guys, just a quick question.
    I’ve been given a project to create an infographic. The visual elements have already been created by someone else within InDesign. I’ve been passed the .indd file and i’m having trouble importing it into After Effects.
    I need to animate each element within the .indd file seperately but they are all in the same layer. The file only contains one layer with lots of subgroups.
    How do I go about importing into After Effects so that I can animate each element seperately?
    Here is the structure:
    Peter Lee-jones replied 12 years, 5 months ago 6 Members · 6 Replies
  • John Cuevas
    December 8, 2012 at 3:59 pm
    You will need to go into ID and manually export the layers, there isn’t any easy way around it.
    Here’s a link explaining the process, if you need it.
    How to move a layout from InDesign to After Effects
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jamie Moore
    December 8, 2012 at 4:16 pm
    I was worried that this was the answer. Just double checking if there was an easier way. Thanks a lot 🙂
  • Vishesh Arora
    December 8, 2012 at 4:51 pm
    Go through this article.
    https://www.surberdesigns.com/tutorial/tutorial-indesign-to-after-effects
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Harold Durnez
    November 5, 2013 at 12:10 pm
    1. Select your work in Indesign,
    2. Copy.
    3. In Illustrator, Paste.
    4. Twirl open the single layer which contains all your sublayers.
    5. options (Layer panel options)
    6. Release to layers (sequence/build)
    7. Select all your sublayers and drag them on top of the 1st layer.
    8. Save out your illustrator file.
    9. Import into AE as Composition – retain layer sizes.
    Hope that helps.
    Harold JM Durnez
    harold.durnez@gmail.com
    http://www.behance.net/HaroldDurnez
    https://vimeo.com/channels/harolddurnez
  • Hylda Von dincklage
    November 19, 2013 at 4:03 am
    This will split everything onto its own layer in Indesign
    var mySels = app.selection.length;
    if (mySels == 0) {
    alert(“Select the object and Run the script”);
    exit(0)
    else{
    while(mySels–){
    var objLayer=app.activeDocument.layers.add();
    app.selection[mySels].itemLayer = objLayer;
  • Peter Lee-jones
    March 4, 2014 at 5:43 pm
    Dear Hylda, how do I write this script in Indesign?
    I have 100 hundred Indesign pages which I need to rebuild in Illustrator for subsequent import into After Effects. I really is hard to believe Adobe didn’t predict this design workflow. I am sure it could be automated in some fashion. Maybe your script is a stating point,
    if (mySels == 0) {
    alert("Select the object and Run the script");
    exit(0)
    else{
    while(mySels--){
    thanks pete
    Pinewood Studios, UK
