Indesign CS4 CLipping path Issues
I have a problem in InDesign CS4 where I’m importing an FPO image, but when I atry to activate the path (Object > Clipping Path > Options, then activate Photoshop path) the ‘activate Photoshop path’ option is not there. However, using exactly the same import settings, with the same image on a colleague’s Mac, the clipping path can be activated.
I can activate the path when i check the ‘Read Embedded OPI Image links’ options upon import, but my image links are not there then! Am I missing something very obvious???
