Activity Forums Adobe InDesign Indesign cannot save my file
  • Indesign cannot save my file
    Posted by Nicki Marotta on March 26, 2014 at 1:06 am
    HELP!!!
    I have spent weeks and weeks doing a 70 page document and it has just suddenly decided not to save the file any more. the message i get is:
    Cannot save “file name”.
    Please, is there anything i can do?
    Juan jesús Millo dominguez replied 12 years, 3 months ago 3 Members · 2 Replies
  • Matt Townley
    April 11, 2014 at 4:50 am
    I’m assuming/hoping you have found the solution for this but if you haven’t I hope it worked out ok for you. This does occasionally happen and the first time it happened to me I freaked out! However, there is a pretty decent work around so stay calm and hang in there – you’ll get through it.
    Here’s what to do:
    1. Go to FILE > EXPORT
    2. Choose FORMAT > IDML
    That will export a working and current version of your project.
    BEFORE YOU QUIT – open the file that you just exported and test to make sure everything is ok.
    If all is well, now save that as a proper InDesign file and then you should be good to go. You can quit and close the other file and should now have a working version that can be saved.
  • Juan jesús Millo dominguez
    May 8, 2014 at 11:00 pm
    I’ve the same problem!
