Activity Forums Adobe After Effects Indescribable selection tool weirdness
  • Indescribable selection tool weirdness
    Posted by Tim Boknecht on September 12, 2014 at 4:20 pm
    I’ve now experienced this a couple times, so it’s becoming a problem. Hoping someone can explain what’s happening and how to fix/avoid it.
    While working in AE with the selection tool selected, instead of the arrow it’s giving me the crosshairs you get when using a shape tool to draw a rectangle, rounded rectangle, ellipse, ect.
    And when I click in the comp window I get what you see here:
    I can drag the corners of the box that shows up to reveal more of the composition like you see here (ignore the mask you see around the edges; it’s from a layer selected in the timeline):
    If I click on another tool, I get the correct tool cursor and AE operates normally, but if I return to the selection tool or use the V shortcut I get the crosshairs again. Shutting down and reopening AE doesn’t fix it. Clearing the cache didn’t work. This problem reared its head earlier this week, but I can’t remember how I got past it.
    What is going on, and how can I make it stop?!
    Tim Boknecht
    Media Producer
    Bravo Productions
    Daniel Waldron replied 12 years ago 2 Members · 3 Replies
  • Daniel Waldron
    September 12, 2014 at 4:29 pm
    It looks like you’re accidentally using the Region of Interest function. It is a button below your comp, right next to the Toggle Transparency button.
  • Tim Boknecht
    September 12, 2014 at 4:37 pm
    OMG, THANK YOU, brother!
    Nonproductivity ended. That was making me seriously crazy.
    Tim Boknecht
    Media Producer
    Bravo Productions
  • Daniel Waldron
    September 12, 2014 at 4:39 pm
    Great. Glad it’s solved. 🙂
