Activity Forums Adobe After Effects Expressions Incrementally increase position.
  • Incrementally increase position.
    Posted by Reynaldo Cortorreal on July 21, 2009 at 4:22 pm
    Anyone know a way to obtain the value of the possition one frame in history? I can’t figure out a way to do this. I previously avoided doing this but that resulted in a history dependent expression that is very hard to alter.
    All i need is:
    5+transform.xPosition.valueAtTime(time-1*thisComp.frameDuration);
    The problem with that is that, it doesn’t work.
    I’ve spent countless hours trying to figure this out and I cant find a solution.
    Reynaldo Cortorreal replied 17 years, 2 months ago 2 Members · 3 Replies
  • Dan Ebberts
    July 21, 2009 at 4:56 pm
    An expression can’t retrieve a value that it calculated on a previous frame . Your choices are to recreate it somehow or to come up with a way to base your caluclation on time.
    The first method generally involves creating a loop that goes frame by frame to recalculate the value you’re looking for.
    The second method is much easier, but it’s not always possible to create the necessary time-based formula.
    dan
  • Reynaldo Cortorreal
    July 21, 2009 at 5:17 pm
    Well that’s a bummer, there should be something that retrieves the current location of the object your moving, dynamically.
    My only other option is to increment a slider that will hold the current value of the position. Not sure if this will work but i will try it.
    July 21, 2009 at 5:27 pm
    The reason I cant base it on time is because I am animating the the speed at which the object moves. I had it set up to animate based on time before, the problem with that was that i could not make the animation speed up without making the contents within the animation speed up along the way.
    I am animating clips moving horizontally on the screen. I want them to move faster at one point and then slow down, without speeding up the playback of the clips.
