Activity Forums Adobe After Effects Expressions Incredibly slow looping sampleimage expression
  • Incredibly slow looping sampleimage expression
    Posted by Paul Roper on February 8, 2016 at 5:36 pm
    Hello,
    I’m trying to determine the height of a wave (a shape layer with just a path and a stroke) at various points along the x-axis. I’ve made (adapted) an expression to do a sampleImage starting at y=0, moving down the comp a pixel at a time, until it finds a pixel whose alpha is greater than 0.
    But it’s unbelievably slow to evaluate, sometimes just timing out. Any suggestions why this is happening? The “for” loop should only be looping a few hundred times to find the pixel. the wave does not change shape, so the expression only needs to evaluate once.
    x=900;
    L=thisComp.layer("audioWave");
    for (i = 0; i <= 1080; i++){
    temp = L.sampleImage([x,i],[0.5,0.5],true,1);
    if (temp[3] > 0) break;
    y=i;
    [x,y]
    Paul Roper replied 10 years, 7 months ago 1 Member · 1 Reply
  • Paul Roper
    February 8, 2016 at 5:41 pm
    Hmmmm….I seem to have fixed it, by making it evaluate every second pixel. I changed i++ to i=i+2 and now I can render a preview faster than realtime! Weird. I’d predict that doing this would make it evaluate twice as fast, not hundreds of times faster!
