Activity Forums Canon DSLR Cameras Incredibly Shaky Pans with Tripod
  • Incredibly Shaky Pans with Tripod
    Posted by Howard Neuthaler on October 8, 2012 at 2:14 am
    I just shot several pans with my Canon T2i (with Magic Lantern) on a tripod, and I cannot believe the amount of vibration/shake that is present in the video. The lens is a Canon 24-70mm f/2.8L. I’m shooting at 24p @ 1/47. The video is at https://youtu.be/K4URHn7Z4Js.
    I’ve used this tripod before (a Ravelli), and I’ve never had this issue. Any ideas what I’m doing wrong? Thanks in advance.
    Howard Neuthaler replied 13 years, 10 months ago 3 Members · 6 Replies
  • Bob Dix
    October 9, 2012 at 10:29 pm
    Have you turned of the Image Stabilizer ?
    Freelance Imaging & Video
    AUSTRALIA
  • Howard Neuthaler
    October 9, 2012 at 10:30 pm
    Thanks for your reply. My lens does not have IS.
  • Bob Dix
    October 9, 2012 at 10:38 pm
    Ah, well try using the image stabilizer in Premiere Pro CS5.5.2 or CS6 if all else fails.
    Good luck !
    AUSTRALIA
  • Howard Neuthaler
    October 10, 2012 at 2:19 am
    Yikes, I don’t use Premier…. Thanks anyway!
  • John Smith
    October 11, 2012 at 3:38 pm
    If it’s the one with the pistol grip then it very well could be from hand shakes, or even the head it self. Ideally you’d want a fluid head and a panning handle so the vibrations would be minimal and the longer lever would give you smooth motion. Is this is the pistol grip model, try fashioning a handle, probably easiest with a metal tube
  • Howard Neuthaler
    October 11, 2012 at 6:55 pm
    Thanks for your reply. The tripod has a fluid head and pan handle. Maybe the shakiness is just a product of the speed of the motion and the focal distance….
