Activity › Forums › Adobe After Effects › Increasing timeline
  • Increasing timeline
    Posted by Tamas Toth on June 9, 2014 at 6:48 pm
    When I first created my composition, I set the time to 1:30, but it seems I will need it a little bit longer. Is it possible to add extra time to the timeline once I started working?
    John Cuevas replied 12 years, 3 months ago 3 Members · 2 Replies
  • George Goodman
    June 9, 2014 at 7:21 pm
    Go to Composition>Composition Settings and change the time there.
    “|_ (°_0) _|”
    Sincerely,
    George
    http://www.vimeo.com/georgegoodman
    http://www.linkedin.com/in/georgefranklingoodman
  • John Cuevas
    June 9, 2014 at 7:36 pm
    To add on to what George said, with the timeline highlighted in the project panel, or if it’s the active panel you are using, press “cntl + K” to open up the Comp Settings. That’s one a shortcut everyone should memorize.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
