Activity Forums Adobe After Effects Increasing the value every frame by a specific ammount
  • Increasing the value every frame by a specific ammount
    Posted by Marko Suto on December 13, 2018 at 9:11 am
    Hello!
    I’m using Soundkeys output to rotate another object . Idea is that object rotates for +soundkeys output. So I need to add the value to the next frame.
    Not exactly sure how to write the expression for object rotation…
    For example: soundkeys output = 1,2,3,4… – my rotation = 1,3,6,10…
    Kalleheikki Kannisto replied 7 years, 8 months ago 2 Members · 2 Replies
  • Marko Suto
    December 13, 2018 at 5:14 pm
    Idea is to have it rotating in the same direction.
    Soundkeys give me a positive or 0 output for each frame, so I wanted to add the value of each frame to the sum of previous rotations.
    Example:
    1. frame soundkeys output = 10
    1. frame rotation = 10
    2. frame soundkeys output = 30
    2. frame rotation = (10+30) = 40
    3. frame soundkeys output = 0
    3. frame rotation = (40+0) = 40
  • Kalleheikki Kannisto
    December 15, 2018 at 5:07 pm
    SoundKeys has a “cumulative” option which should do this automatically.
    Senior Graphic Designer
