Activity Forums VEGAS Pro Increasing Preview Display Resolution
  • Increasing Preview Display Resolution
    Posted by Johan Windh on June 15, 2011 at 10:02 pm
    Hi all.
    I just upgraded from SV 9 to 10. (mostly to get rid of choppy playback issues with HD material). However, I cannot even see if there is a difference, since the preview resolution of the project I work on is lower when I open the project with SV 10…
    Check these screencaps:
    SV9
    SV10
    You see the difference..
    I´ve been searching for an hour on how to change the preview res, but have found nothing.
    Any help appreciated!
    /Johan
    Johan Windh replied 15 years, 3 months ago 2 Members · 3 Replies
  • Johan Windh
    June 15, 2011 at 10:30 pm
    Hmm.. well I sorta semi-fixed it myself.. By right-clicking the preview window—> Preview Video —> Checked “Display at Project Size” and checked “Simulate Device Aspect Ratio” (to get rid of the interlace)..
    Looks a whole lot better now.. And smooth running!
  • Nigel O’neill
    June 16, 2011 at 3:37 am
    Your preview performance depends primarily on the CPU grunt of your system. HD is quite demanding compared to, say, DV.
    You could invest in a product called Gearshift which creates proxy files to edit with which improve preview performance tremendously.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Johan Windh
    June 16, 2011 at 7:17 am
    Hi Nigel. Well, I do get good and smooth playback now, in high res, after my changes.
    (edit: I changed it to “fit to screen”, in order to get rid of interlace, nothing else)
    Thanx anyway!
    /J
