Activity Forums Maxon Cinema 4D increasing polygon segments in imported mesh
  • increasing polygon segments in imported mesh
    Posted by Michael Banjoko on December 17, 2009 at 1:52 pm
    This is a follow-up to the ‘realistic grass’ problem in C4D arch version.
    I’ve imported my grass mesh into c4d and attempted using “matrix extrude” to create a 3dgrass effect. Though it’s working, my polygon segments are too wide, and thus make the extrusions appear more like rashes than ‘marshes’.
    How can i increase the polygon segments on the imported mesh?
    Michael Banjoko replied 16 years, 9 months ago 2 Members · 6 Replies
  • Adam Trachtenberg
    December 17, 2009 at 9:47 pm
    You can select the object and run Function>Subdivide.
    Instead of doing it that way I would try using material displacement — subpolygon displacement and a small scale noise (FBM noise works well).
  • Michael Banjoko
    December 18, 2009 at 6:57 pm
    Thanks. I’ve decided to take your material displacement option. Having done the sub-polygon bit, where do i effect the ‘noise’, and FBM?
  • Adam Trachtenberg
    December 18, 2009 at 7:28 pm
    The noise shader goes in the displacement channel and FBM is one of the noise types you can choose.
  • Michael Banjoko
    December 18, 2009 at 7:52 pm
    Found it, thanks. It does however take its time to render. I guess that’s because of the quality coming. Many thanks
  • Adam Trachtenberg
    December 19, 2009 at 5:38 pm
    It takes a long time to render because there’s a bazillion polygons. I should have thought of this earlier, but if you have the Hair module, that might give you a faster/better result.
  • Michael Banjoko
    December 20, 2009 at 11:07 pm
    I’ve looked extensively but my C4D architecture version 10 doesn’t appear to have the hair module. Could it be tucked away somewhere i’m not looking?
