Activity Forums Adobe After Effects increasing numbers in text
  • increasing numbers in text
    Posted by Reanimator1 on October 28, 2005 at 5:52 pm
    I’m trying to have numbers increase infinitely starting at 1.6 million. I tried using the numbers effect but the max amount that it can go is 30.000 and there is an expression preset for frame numbers but I don’t know how to modify the expression to start at a higher number because obviosly I can’t go 1.6 million frames in the comp. Can anyone help?
    Sean
    Reanimator1 replied 20 years, 10 months ago 2 Members · 2 Replies
  • Dan Ebberts
    October 28, 2005 at 6:48 pm
    Well, I don’t know about infinitely, but you can use a text layer with an expression to count up to 999999999999999.
    Here’s an example that counts from 1600000 to 999999999999999 over 4 seconds:
    startCount = 1600000;
    endCount = 999999999999999;
    countDur = 4;
    Math.round(linear(time,0,countDur,startCount,endCount))
    Dan
  • Reanimator1
    October 28, 2005 at 7:10 pm
    Dan,
    Thanks a lot, that’s just what I needed.
    Thanks again,
    Sean
