Activity Forums Maxon Cinema 4D Increasing HUD view distance
  • Increasing HUD view distance
    Posted by Jason Coursey on February 16, 2009 at 1:27 am
    Hi, Cow.
    Does anyone have any idea how to increase view distance in the viewer? I have a rather large scene, but the viewer clips and won’t let me view objects if I pull the camera back in space.
    I’ve done searches on the internet and looked all inside C4D, but can’t find anything.
    Jason
    Steve Santer replied 10 years, 10 months ago 4 Members · 4 Replies
  • Adam Trachtenberg
    February 16, 2009 at 3:51 pm
    Try running the viewport>edit>frame default function to restore the editor camera’s original settings. Be mindful of when you’re trucking the camera in/out vs. zooming the camera in/out. If you indadvertently zoom in too far you can have these sorts of problems and the viewport becomes balky.
    As a general rule it’s a good idea to keep your scenes within the approximate area of the default grid. If they’re a lot larger, and also if they’re very very small, you can run into floating point problems that make navigation difficult.
  • Jason Coursey
    February 16, 2009 at 7:40 pm
    Thanks for the response, Adam. I appreciate the help!
    JC
  • Greg C neumayer
    April 1, 2015 at 9:58 pm
    I always forget this. In R16, go to your top menu bar:
    Edit > Project Settings > View Clipping
  • Steve Santer
    October 30, 2015 at 12:02 am
    Thanks for adding that info Greg. It’s the same for R17 too.
