Activity › Forums › Apple Final Cut Pro Legacy › Increasing a clips volume past +12db in the timeline
  • Increasing a clips volume past +12db in the timeline
    Posted by David Dubois on March 22, 2007 at 9:47 am
    Hi All
    I’m looking for a way (without destructive editing/affecting the clip) to increase a few clips in the film I’m working on.
    I have the mixer turned up to max for these clips but it’s not enough. I know I’ll introduce a lot of hiss/ noise but I’m not too bothered about that at the moment as it’s for a screener for the producers – they know it needs some ADR and audio-post work.
    Anyone have any suggestions other than going into STP and back again (which I admit might be my only option)?
    Thanks in advance
    Dave
    Currently working on ‘Lookin’ For Lucky’ – Feature Film for Albino Injun Productions.
    http://www.lookinforlucky.co.uk
    John Davidson replied 19 years, 6 months ago 6 Members · 8 Replies
  • 8 Replies
  • Martin Baker
    March 22, 2007 at 9:58 am
    Apply the Effects > Audio Filters > Apple > AUPeakLimiter to the clip
    then you can get up to 40dB of gain by adjusting the Pre-Gain slider.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! Final Print for FCP
    Hot Tips video podcast
  • Lee Berger
    March 22, 2007 at 10:05 am
    You can also use the AUDynamics filter which has the same Master Gain, plus the option of adding some compression.
  • Rafael Amador
    March 22, 2007 at 11:28 am
    Hi Dave,
    The easier way, I think, is just to duplicate the same audio in another channel.
    Cheers,
    rafael
  • Randy Johnson
    March 22, 2007 at 11:43 am
    Yea if your in a hurry you can just copy the clip onto another layer.
    If you have soundtrack you can bring the clip into the editer and use that…duplicating the clip works there too and you have noise reduction options.
  • David Dubois
    March 22, 2007 at 2:49 pm
    Brilliant! Thanks guys!
    I’ll try the filter before I double up layers (so as not to cause issues in soundtrack later).
    Dave
  • John Davidson
    March 22, 2007 at 9:58 pm
    I hit that wall often, so I created a favorites filter effect for dynamics processing with about an 8 pt boost. I rarely have to do any additional adjustment, but if so it’s fairly straightforward.
    Here’s howto set it up. Once you have your master gain of the dyn proc effect to the point you like, drag the effect from the viewer into your favorites folder. If you find you’re using this for more than one or two effects, you may want to select all and then drop ALL of your audio by about 4 or 5 ticks (opt-cmd-L, I think). It’s always better to go without an effect if possible.
  • Rafael Amador
    March 23, 2007 at 3:29 pm
    Jhon,
    you use the Apple AUDinamic Procesor?
    rafael
  • John Davidson
    March 27, 2007 at 7:22 am
    Yep, that’s the one.
