Activity Forums Avid Media Composer Increased render time with custom effects
  • Increased render time with custom effects
    Posted by Jeremy Newmark on July 18, 2005 at 2:14 pm
    I have a small problem with rendering custome effects on MCA 2.1 running on a HP 8000. For example if I create a resize on a clip and render it out, it goes pretty fast, but if I save that effect to a bin and use it somewhere else, it will take up to 10 times longer to render, then if I simply re-create the effect. Does anyone know why this is or know of any easy workaround? Any help would be greatly appreciated.
    Jeremy Newmark
    Carl Amoscato replied 21 years, 1 month ago 2 Members · 1 Reply
  • Carl Amoscato
    July 18, 2005 at 4:26 pm
    Hi Jeremy,
    Check your render settings, and make sure it’s set to “Quality Set in Each Effect” rather than “Highest Quality.”
    good luck,
    Carl
