Activity Forums Adobe After Effects Expressions Increase position with comp markers
  • Increase position with comp markers
    Posted by David Cabestany on October 2, 2017 at 8:36 pm
    I’d like to sync the movement of a layer with the markers of a comp, which in turn I’m already using to increment the value of a repeater on a shape layer.
    Basically I need for the layer to slide x amount of pixels each time it passes a marker.
    Is it possible?
    David Cabestany replied 8 years, 11 months ago 2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    October 2, 2017 at 10:42 pm
    Something like this maybe:
    sx = 100; // slide distance
    sd = .25; // slide duration
    m = thisComp.marker;
    x = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (time < m.key(n).time) n--;
    if (n > 0){
    t = time - m.key(n).time;
    x = ease(t,0,sd,(n-1)*sx,n*sx);
    value + [x,0]
    Dan
  • David Cabestany
    October 2, 2017 at 11:13 pm
    This is perfect Dan, thanks.
    All I changed was the slide duration to 0, so the movement is more like hold keyframes.
    One question, though, on the value of n you subtract one unit each time the marker increases its value, since the markers are always increasing its value why is n not adding a unit after each loop, in other words why the expression isn’t n++ instead of n–?
    Thanks again,
    D.
  • Dan Ebberts
    October 2, 2017 at 11:20 pm
    If you just want it to jump at each marker, you could do it like this:
    sx = 100; // jump distance
    x = 0;
    if (m.numKeys > 0){
    x = n*sx;
    value + [x,0]
    As to your other question, there is no loop. The algorithm is just finding the most recent, previous marker. The n– happens only when nearestKey() returns the next marker, instead of the previous one (when the current time is closer to the marker on its right than it is to the one on its left).
    Dan
  • David Cabestany
    October 3, 2017 at 7:09 pm
    Thanks a lot for the explanation Dan.
  • David Cabestany
    October 6, 2017 at 2:41 am
    Hey Dan, wondering if you could help me to further enhance this expression.
    I’m using it now to displace the y value instead of the x, but the jumps need to be irregular, meaning some times it needs to jump 55 pixels and others 110.
    I added a slider to control the sx variable and keyframed the value using hold keyframes, the first jumps were ok, at first it moved 55 pixels and then 110, however when I need it to go back to 55 pixels per increment, it went down instead of jumping up as it was doing before.
    Can you help me so it always goes in one direction?
  • Dan Ebberts
    October 6, 2017 at 3:30 am
    sy = effect("Slider Control")("Slider");
    y = 0;
    if (m.numKeys > 0){
    for (i = 1; i <= n; i++){
    y += sy.valueAtTime(m.key(i).time);
    value + [0,y]
    Dan
  • David Cabestany
    October 6, 2017 at 8:53 pm
    Just saw this. It’s perfect, thanks so much.
