Activity › Forums › Adobe After Effects Expressions › increase number by one
  • increase number by one
    Posted by Anders Hattne on February 1, 2012 at 5:09 pm
    Hello there, I’m in a rush and can’t find anything in fast enough searching.
    We are doing this vocal sync animation with the puppet tool, triggered with audio to keyframes. It’s a comp of the mouth opening time remapped so it jibbers to the sound.
    To get some variation I thought I’ll put a second layer on top where the opacity would alternate every time the value hits 0.
    This is the expression so far… in the opacity
    a =0;
    input=comp(“03_cap v2”).layer(“Light Gray Solid 3”).effect(“Sound Keys”)(“Output 1”);
    soundk=linear(input, 3, 12, 0 , 100);
    if (soundk == 0) {a ++};
    if (a % 2 ==0) {100}
    else 0
    I was hoping the value a would increase and that way every other time the upper layer would be visible. But I assume the a++ doesn’t work as the value of a is set to 0 every time the expression is run.
    Would there be a better way to do this?
    http://www.ardillamedia.com
    Anders Hattne replied 14 years, 8 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 1, 2012 at 5:31 pm
    Expression variables don’t persist from one frame to the next. You could rework my beat counter to use your soundkeys output:
    https://www.motionscript.com/design-guide/audio-count.html
    Dan
  • Anders Hattne
    February 1, 2012 at 6:21 pm
    Yes, I had a look at that one but figured I didn’t get any of that. Learned helplessness..
    when you mentioned it I figured I don’t need to understand it and just added
    if (n % 2 ==0) {100}
    else 0
    to the end. And that did the trick. Hopefully I get around to understand the beat counter later.
    Many thanks”
