Activity Forums Adobe After Effects Increase Effects MAX Value
  • Increase Effects MAX Value
    Posted by Jon Herron on October 17, 2008 at 7:46 pm
    Is there a way to increase the value (the maximum value) of the slider control for effects??
    Yes you can right click and change the value, BUT it still has a MAX setting. Can this be changed???
    i.e.
    Specifically the Z jitter amount in Card Wipe
    thanks
    jon
    Roland R. kahlenberg replied 17 years, 10 months ago 2 Members · 3 Replies
  • Roland R. kahlenberg
    October 18, 2008 at 2:46 am
    All Effect Parameters will have the true maximum displayed in the top-right corner. This value is different from the visible maximum value displayed via the default sliders.
    To ‘stretch’ the slider values, simply change the Slider Range’s maximum value to a value equal to or less than the parameter’s stated maximum value.
    HTH
    RoRK
    broadcastGEMs.com – the leader in customizable royalty-free animated backdrops
  • Jon Herron
    October 27, 2008 at 4:18 pm
    Thanks for the reply!
    I know about the true maximum displayed in the top-right corner. Is there a way to actually change that value.
    Possibly via an expression????
    Thank you
    Jon
    October 27, 2008 at 4:30 pm
    Woah!!! I’ve not used the jitter settings for ages but my recollection is that they jitter A LOT. I’m not too sure why you need to max that out.
    Perhaps you can try to add a wiggle to the max. amount.
    As for increasing the wamimum value there, you can try it for yourslf although I doubt it will work. Just type a value higher than the stipulated maximum value. If the value you typed is beyond the limit that the plugin can handle, then it should revert to the maximum value allowable.
    Cheers
    RoRK
