Activity › Forums › Adobe After Effects Expressions › Incorrect layer movement expression
  • Incorrect layer movement expression
    Posted by Boris Norkin on December 7, 2020 at 3:49 pm
    Hi there!
    I have such an expression on a position of a layer:
    var distance = [0,0];
    var p0 = toComp(anchorPoint, 0);
    var res = [0,0];
    for(var cF = 0; cF < timeToFrames(time); cF++)
    distance = (thisComp.layer(“Target Layer”).toComp(anchorPoint) – toComp(anchorPoint, time – 0.1)) * 0.5;
    res += distance;
    p0 + res
    The idea was that at the first frame the layer would go 1/2 of the distance to a target layer. Next frame 1/4 and etc.
    And if I move the target layer the layer with an expression should smoothly change its direction to it.
    But instead I got an uniform movement of the layer in direction of the target layer.
    Is there a mistake in that expression or am I just not understanding how expressions work and, for example, AE can’t let an expression to refer to its state in a previous frame or something like that?
    Dan Ebberts replied 5 years, 9 months ago 2 Members · 1 Reply
  • Dan Ebberts
    December 7, 2020 at 5:12 pm
    That’s correct. However, it looks like your expression is already set up to loop through all previous frames (which is one way to work around the expressions-have-no-memory issue). You can take advantage of the time parameter of toComp() to get the frame-by-frame position of the target layer:
    thisComp.layer("Target Layer").toComp(anchorPoint,framesToTime(cF))
    and use that to calculate on the fly how the layer with the expression should respond on a frame-by-frame basis.
