Activity Forums Adobe After Effects Inconsistent transparency
  • Inconsistent transparency
    Posted by Cutter Johnston on April 27, 2007 at 10:43 pm
    I am re-using a video 25 times in a comp. When I toggle the transparency grin on and off 5 of the instances of the clip have a transparent background and the rest hold a black background. All were brought in exactly the same and the setting look exactly the same. Can anyone point me in the right direction so I may make them all behave the same? I have been round and round the settings chasing my tail
    Cutter Johnston replied 19 years, 4 months ago 2 Members · 2 Replies
  • Darby Edelen
    April 27, 2007 at 10:47 pm
    Where is the video coming from? If it has an alpha channel, is it properly interpreted?
  • Cutter Johnston
    April 28, 2007 at 1:58 am
    Thanks for the info. You inspired me to retrace the steps again. One batch of the 14 image sequences that made up the entire clip was silhouette alpha mode. This segment of the clip appeared five times. Again, thanks.
