Activity Forums Apple Final Cut Pro Legacy inconsistent transitions – cross dissolve and fade to black
  • inconsistent transitions – cross dissolve and fade to black
    Posted by Ira Liss on January 2, 2009 at 11:36 pm
    I’ve been using the default FCP transition that goes for 1 second
    and cross dissolves between two shots.
    I select the vertical line between shots, hit command T,
    and then render (command R).
    Somehow, unintentionally, one of my transitions had the
    scene fade to black, and then cut to the next shot.
    It’s mysterious because I don’t remember changing any settings.
    Are there keystroke commands that I may have hit accidentally
    that would have made a transition fade to black one minute,
    and cross dissolve the next?
    Also —
    I’ve gone into the “cross dissolve” tab with its settings and diagram
    showing the fades as buttons with triangles. I played with the settings
    a bit to understand how they work.
    But I didn’t see a result or difference right away
    when I reran/rerendered the sequence.
    Is there an “apply” button that I don’t know about?
    Thank you all for your help!
    – Ira Liss
    storyboards
    and graphics
    Kenny Powerass replied 17 years, 7 months ago 3 Members · 6 Replies
  • Glenn Fisher
    January 3, 2009 at 12:19 am
    It may be possible for a cross dissolve to look like a fade to black if there is black at either the end of the first clip or the beginning of the second clip. I would check both clips to make sure you have the appropriate handles, and that the video in neither one cuts out to black.
    The way the cross dissolve transition works is that it essentially extends the length of your clips by 30 frames (assuming it’s a one second dissolve). So even though the clip in your timeline without the cross dissolve (i.e. with a cut between the two clips) may not show any black, the cross dissolve will extend the out point of the first clip and the in point of the second clip by 30 frames. If there is black in either of those two clips in that 30-frame section, then the cross dissolve will show that, and it will look like a fade to black.
    Hope that helps,
    Glenn Fisher
  • Ira Liss
    January 3, 2009 at 12:40 am
    Hello Glenn,
    Thank you for your helpful comments.
    I think I understand what you’re speaking of.
    The thing is,
    the clips come from a continuous interview I’ve
    been editing from, that is, 2-3 minute interviews
    where the camera ran continuously (no stops and
    starts during the interview).
    I loaded a number of complete 2-3 minute interviews
    to my Mac. Now I’m going through the footage
    selecting 20 to 35 second clips, and placing
    them in the time line.
    I am supering titles over the beginnings of different
    clips to give the viewer quick summary text that
    tells them what the clip is about.
    I’m fading the titles on and off and
    doing cross dissolves between clips.
    (These short videos will be going on the web
    with video still frames as start buttons.)
    Anyhow, i don’t yet understand how 30 frames after
    or before my edits would have black frames.
    One more thing —
    I’d actually like to use this simple fade to black effect
    intentionally at the end of some of the clips (as opposed
    to cross dissolves).
    May I ask for help in how best
    to do fade to blacks? (I’ve done it okay
    by accident, and now, I can’t seem to
    do this on purpose.)
    Thanks again,
    – Ira Liss
    storyboards
    and graphics
  • Glenn Fisher
    January 3, 2009 at 1:03 am
    Hehe, unfortunately I don’t think I can help with your issue, but I can certainly help you to intentionally fade to black! It’s very easy. In the Final Cut “Browser” window, click on the “Effects” tab. From there, click the disclosure triangle for “Video Transitions” and then the triangle for “Dissolves”. At that point, a “Fade In Fade Out Dissolve” will do a fade to black between two clips.
    Additionally, you could keyframe the opacity of each clip and as long as there is black underneath the video track, or you’re only working with one track (i.e. the V1 track), then by keyframing the opacity you can essentially create your own fade to black transition. To do this, I set the playhead in the timeline to where I want the fade to start. Double click the clip to load it into the viewer. Choose the “Motion” tab, and then click on the disclosure triangle for “Opacity”. You will see a slider that corresponds to the number next to it (it will default to 100 since it has 100 percent opacity…or you “can see 100% of it”). To the right of that number, you’ll see a rhombus-like shape. By clicking on that, you’ll set a keyframe, which tells final cut that you want the opacity to be 100% at that point in time. You can then go back to the timeline and position the playhead to where you want the fade to end (99.9% of the time that will be at the end of the clip). The position of the playhead should automatically be reflected in the viewer. Once you have moved the playhead in the timeline, go back to the viewer and set the opacity to 0 by either typing 0 into the box or moving the slider all the way to the left. That automatically sets another keyframe at that point in time telling Final Cut that you want the opacity to be zero. Final Cut will “interpolate” between the two keyframes, which makes for a constant decrease of opacity between the 100% and 0% keyframes.
    I hope that helps!
    – Glenn Fisher
  • Ira Liss
    January 3, 2009 at 1:08 am
    Glenn,
    Thank you for taking the time to
    write up such a detailed description.
    (It’s a great tutorial!)
    Looks like I’ll be able to follow
    it pretty easily.
    I appreciate your
    help very much!
    Sincerely,
    – Ira Liss
  • Glenn Fisher
    January 3, 2009 at 1:10 am
    I’m glad that I could help! 🙂
    – Glenn Fisher
  • Kenny Powerass
    January 5, 2009 at 4:14 am
    Is it possible that there’s a small space between your two clips?
    If so, you may have selected the end of the first clip rather than the joint between two clips. The crossfade you added would act as a fade to black (provided there’s no clip on a lower track) and your next clip would just pop onscreen rather than fading in.
