Activity Forums Maxon Cinema 4D inconsistent cloth mesh deformation
  • inconsistent cloth mesh deformation
    Posted by Manojit Ghose on March 13, 2010 at 12:12 pm
    i am using the cloth tag to disintegrate a text object (converted to mesh) however i have slight problem… the letter (As circled 1 in the image posted below)”S”‘s caps would deform very nicely..however the caps of letters (As circled 2 and 3 in the image posted below) “I,F,A” wont deform in a cloth-like manner as the caps of “S” would. they look much more stiff.
    any workaround suggestion would be very welcome.
    i am fairly new in c4d.
    here is the numbered screen shot:
    https://www.postimage.org/image.php?v=Pqzk9x0
    MG
    Adam Trachtenberg replied 16 years, 6 months ago 3 Members · 4 Replies
  • Randy Johnson
    March 13, 2010 at 12:44 pm
    Cloth is sensitive to how many polygons you have and howmany of those are triangles and so on. This means you will have a hard time getting a consistant result since your caps are N-gons.
    For a solution I would suggest that you change the caps in your extrude nurbs from the default N-gons to Quads, then enable the grid option.
    /Randy
  • Manojit Ghose
    March 13, 2010 at 9:15 pm
    Dear Randy,
    thanks for answering to my post. i thought similar…but was not able to figure out how to convert to ngons into quads. i found triangulate and a couple of other options in the functions menu…however i was not able to find the quadrangulate options. i know its a utter noob question!! but i would indeed appreciate.
    regards
    MG
  • Manojit Ghose
    March 13, 2010 at 9:24 pm
    dear randy and everyone,
    i guess i found it. i think you were talking about the quad options in EXTRUDE NURBS>CAPS>TYPE options. however it doesn’t solve the issue i was having in the firstplace. the straight letters are still too stiff.
    any suggestions would be very welcome.
    regards
    MG
  • Adam Trachtenberg
    March 14, 2010 at 3:14 am
    Randy is right about the caps, but you’ll also want to change your text spline to “Intermediate Points>Subdivided” and reduce the maximum length setting.
