Activity › Forums › VEGAS Pro › Inconsistent brightness or colour.
  • Inconsistent brightness or colour.
    Posted by James Spicer on February 13, 2019 at 10:21 pm
    I posted a thread not long ago but wanted to start a new one fresh.
    I was hoping someone could answer on the way Vegas handles brightness etc.. Here are the things I’ve noticed editing video:
    The Vegas preview window shows a brighter image than i get playing a rendered .mp4 in windows media player & VLC, the colours look correct in those players with that file type. But..
    An uncompressed .avi from Vegas shows brighter in windows media player than in VLC. Why? Graham mentioned in my other thread that VLC is crushing the blacks, but to me media player is showing it looking wrong.
    x264 .avi rendered video from Vegas looks bright no matter what player i play the file in. This i do not understand either.
    Lastly, if i take a snapshot in the Vegas preview window and view it outside of Vegas, it looks bright like the preview window, if i import it back into Vegas and render it with the video in .mp4 it looks like it should to me (not over bright) in either media player or VLC. Is that normal?
    How do i get consistency here? I’ve been confused with this. Hoping someone can explain or tell me how i can easily get past this.
    Francois Pénzes replied 7 years, 6 months ago 3 Members · 5 Replies
  • Ole Kristiansen
    February 13, 2019 at 11:09 pm
    First you should not use preview window for color grading – but I have previously used Preview Levels in Sony Vegas Pro 13!
    There is a German who has made a small dll file – for Sony Vegas Pro 12/13 – which makes it a little easier – here you can choose between Original – Pc – Tv! Original shows 16 – 235 PC shows 0 – 255 – TV shows how it will typically look on an LCD TV – here you can also change the settings! The advantage here is that when you render / export – it automatically switches back to Original!
    I have attached Preview Levels – see my video back from 2015 – how easy it is to “install”
    Antares PreviewLevels for Vegas 12
    file:///I:/Harddisk%20C/Temp/PreviewLevels_1_2/PreviewLevels_readme_en.html
    Sony Vegas Pro 12 / 13 Preview Levels
  • https://www.youtube.com/watch?time_continue=8&v=7kyHxDZ0VL4
  • Ole Kristiansen
    February 13, 2019 at 11:23 pm
    PreviewLevels for Vegas 12 / 13
    https://f1.creativecow.net/13111/13111
  • James Spicer
    March 8, 2019 at 11:44 am
    Hi, thanks for the reply. Yes i already have this extension which i got recently as suggested by someone else.
    The problem is also the rendered video, AVC mp4 is the only thing that comes close looking like the original file, and if i use the preview levels set to PC it does look close to the original file (as i see in VLC) in the preview window.
    If i render to AVC mp4 and view the video in VLC, the colours are still not 100% the same as the original video, it’s close but i can see that reds are a bit brighter for example. If i render to most other formats then it comes out looking too bright in VLC, much the same as viewing the “original” setting with preview levels in the preview window.
    So that extension is pretty much only good for rendering to AVC mp4, even then the colours aren’t exactly the same as what’s seen in the rendered file, it’s close however.. and I’m getting tired of trying to figure this out so i might have to just go with this, and then use levels fx if rendering to most other codecs.
    Looks like I’ll have to make do with close enough, rather than exact.
  • James Spicer
    March 8, 2019 at 11:48 am
    “even then the colours aren’t exactly the same as what’s seen in the rendered file”
    Correction, aren’t exactly the same as what’s seen in the original file.
  • Francois Pénzes
    March 8, 2019 at 2:30 pm
    Hi James
    Tom Brady posted this a while back but it’s still relevant.
    https://www.cinematography.com/index.php?showtopic=56262#entry372768
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
  • We use anonymous cookies to give you the best experience we can.
