Activity › Forums › Compression Techniques › Inconsistent bad ProRes outputs (video and audio out of sync)
  • Inconsistent bad ProRes outputs (video and audio out of sync)
    Posted by Evan Griffin on July 16, 2013 at 9:14 pm
    Running batch conversions of H.264 5D/7D footage to ProRes 422 LT results in a large number of files with out of sync audio and video. I opened the out of sync clips in Quicktime Pro, looked at the properties and saw that the video and audio tracks had different durations. One example is video duration: 46.96. Audio duration: 46.79. All of the out of sync clips have this problem with the video/audio duration and it’s always video that’s longer than audio. The source H.264 files have the same duration for audio and video tracks.
    I tried running my transcodes in Squeeze 9 Pro, Squeeze 8.5 Pro, and MPEG Streamclip. Streamclip produced more correct files than Squeeze, but there were still some that were wrong. I’m going to be ProResing hundreds of clips and I can’t check them individually.
    I also tried running the transcodes on another computer with Squeeze 8.5 Pro and Streamclip and the outputs were fine. I think the problem is related to my computer somehow (corrupt or incomplete codecs, a hardware problem, etc.).
    Any help with this is really appreciated!
    Mac Pro Mid 2012
    12-core 2.4 GHz Intel Xeon | 48 GB 1333 MHz DDR3 ECC | ATI Radeon HD 5770 | 500 GB SSD
    PCI: Sonnet Tempo SATA E4P | CalDigit Super Speed PCI Express USB 3.0
    Evan Griffin replied 13 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
