Activity Forums Apple OS X Inconsistant Error -36 when copying files
  • Inconsistant Error -36 when copying files
    Posted by Tim Wingert on January 15, 2014 at 10:53 pm
    Hello!
    In transferring files from my internal RAID to an external drive, the “some data in File XXXXX cannot be read/written” error -36 keeps popping up.
    The thing is– that sometimes I CAN move the file mentioned in the error message if I just move that file alone, and not in a large group, or in a subfolder.
    I’ve messed with read/write permissions and verifying/repairing all the disks involved.
    I’m running Mavericks.
    Any ideas?
    Tim
    Chris Murphy replied 12 years, 7 months ago 3 Members · 10 Replies
  • 10 Replies
  • Gary Milligan
    January 16, 2014 at 3:12 am
    Is the external drive a new drive? If so, is it formatted for Mac?
  • Tim Wingert
    January 16, 2014 at 1:00 pm
    The external is a Mac-formatted 3TB SATA drive in a USB external dock.
  • Gary Milligan
    January 16, 2014 at 8:54 pm
    Sorry Tim… I got nuthin’. Hopefully someone with a broader knowledge base will step in.
    Good luck.
  • Chris Murphy
    January 22, 2014 at 8:26 am
    Go to the Console application, click system.log, click Clear Display, reproduce the problem, note and post what’s newly added in Console.
    Go to Disk Utility, click on the drive icon with model number etc. (not the name of the volume), and click the Info button in the toolbar. Scroll down to the SMART section and copy-paste what’s there.
  • Tim Wingert
    January 23, 2014 at 3:09 pm
    From system Log:
    Jan 23 10:03:30 edits-mac-pro.imsav.local com.apple.quicklook.satellite[1393]: [QL] Setting up sandbox for failed, exiting!
    Jan 23 10:03:30 edits-mac-pro com.apple.launchd[1] (com.apple.quicklook.satellite.034F4C43-9B48-4573-B0A9-1FED3E49D931[1393]): Exited with code: 255
    Jan 23 10:03:30 edits-mac-pro com.apple.launchd[1] (com.apple.quicklook.satellite.034F4C43-9B48-4573-B0A9-1FED3E49D931): Throttling respawn: Will start in 10 seconds
    Jan 23 10:03:45 edits-mac-pro.imsav.local globalsand[66]: GLO Daemon: Unable to connect to the persistent target “LIO Target” at 172.25.1.6 (0xe00002f0 – iSCSI portal was not found at the specified address).
    Jan 23 10:04:14 edits-mac-pro kernel[0]: smb2fs_smb_cmpd_create: Second close failed 9
    Jan 23 10:04:14 edits-mac-pro kernel[0]: 0xffffff83a4d33ea8, 0x2e005ea Intel82574L::rxFrame – blocking allocate OK
    Jan 23 10:04:14 edits-mac-pro kernel[0]: FindFileRef: pid not matching
    Jan 23 10:04:50 edits-mac-pro com.apple.launchd[1] (com.apple.quicklook.satellite.034F4C43-9B48-4573-B0A9-1FED3E49D931[1394]): Exited: Killed: 9
    Jan 23 10:04:54 edits-mac-pro.imsav.local globalsand[66]: GLO Daemon: Unable to connect to the persistent target “LIO Target” at 172.25.1.6 (0xe00002f0 – iSCSI portal was not found at the specified address).
    Jan 23 10:06:03 edits-mac-pro.imsav.local globalsand[66]: GLO Daemon: Unable to connect to the persistent target “LIO Target” at 172.25.1.6 (0xe00002f0 – iSCSI portal was not found at the specified address).
    Jan 23 10:06:12 edits-mac-pro.imsav.local firefox[206]: invalid context
    Jan 23 10:06:54 edits-mac-pro kernel[0]: AppleRAID::completeRAIDRequest – error 0xe00002ca detected for set “Local Video” (E08FB46B-DDE5-43AD-B541-E6484E8F04DF), member E7E30B03-70BC-4244-87D5-079DA684E3BF, set byte offset = 289144029184.
    Jan 23 10:06:54 edits-mac-pro kernel[0]: disk4: I/O error.
    Jan 23 10:07:03 edits-mac-pro.imsav.local globalsand[66]: GLO Daemon: Unable to connect to the persistent target “LIO Target” at 172.25.1.6 (0xe00002f0 – iSCSI portal was not found at the specified address).
    Jan 23 10:08:12 edits-mac-pro.imsav.local globalsand[66]: GLO Daemon: Unable to connect to the persistent target “LIO Target” at 172.25.1.6 (0xe00002f0 – iSCSI portal was not found at the specified address).
    Jan 23 10:08:22 edits-mac-pro com.apple.launchd[1] (com.apple.quicklook.satellite.034F4C43-9B48-4573-B0A9-1FED3E49D931[1405]): Exited: Killed: 9
    Jan 23 10:08:28 edits-mac-pro com.apple.launchd[1] (com.apple.quicklook.satellite.034F4C43-9B48-4573-B0A9-1FED3E49D931[1434]): Exited: Killed: 9
    Jan 23 10:08:28 edits-mac-pro com.apple.launchd[1] (com.apple.quicklook.satellite.034F4C43-9B48-4573-B0A9-1FED3E49D931): Throttling respawn: Will start in 4 seconds
  • Tim Wingert
    January 23, 2014 at 3:26 pm
    The file in question lives on a 3-slice RAID 0…so I can’t really pin down where it lives. Here’s the info on one of the 3 slices:
    S.M.A.R.T. Status : Verified
    Raw Error Rate : 000000000000
    Spinup Time : 000000001068
    Start/Stop Count : 000000000217
    Reallocated Sectors : 000000000130
    Seek Error Rate : 000000000000
    Power-On Hours : 000000003D7A
    Spinup Retries : 000000000000
    Calibration Retries : 000000000000
    HDD Temperature : 000000000022
    Reallocated Sector Events : 00000000012F
    Current Pending Sectors : 00000000059B
    Offline Scan Uncorrectable Sectors : 000000000000
    CRC Error Rate : 000000000000
    Multi-Zone Error Rate : 0000000132E4
  • Chris Murphy
    January 23, 2014 at 3:42 pm
    Is disk4 AppleRAID, or is it a member disk? Try this command if you don’t know:
    diskutil list
  • Tim Wingert
    January 23, 2014 at 3:44 pm
    /dev/disk0
    #: TYPE NAME SIZE IDENTIFIER
    0: GUID_partition_scheme *1.0 TB disk0
    1: EFI EFI 209.7 MB disk0s1
    2: Apple_RAID 999.9 GB disk0s2
    3: Apple_Boot Boot OSX 134.2 MB disk0s3
    /dev/disk1
    0: GUID_partition_scheme *1.0 TB disk1
    1: EFI EFI 209.7 MB disk1s1
    2: Apple_RAID 999.9 GB disk1s2
    3: Apple_Boot Boot OSX 134.2 MB disk1s3
    /dev/disk2
    0: GUID_partition_scheme *1.0 TB disk2
    1: EFI EFI 209.7 MB disk2s1
    2: Apple_RAID 999.9 GB disk2s2
    3: Apple_Boot Boot OSX 134.2 MB disk2s3
    /dev/disk3
    0: GUID_partition_scheme *1.0 TB disk3
    1: EFI EFI 209.7 MB disk3s1
    2: Apple_HFS OS Disk 999.3 GB disk3s2
    3: Apple_Boot Recovery HD 650.0 MB disk3s3
    /dev/disk4
    0: Apple_HFS Local Video *3.0 TB disk4
    /dev/disk5
    0: FDisk_partition_scheme *500.1 GB disk5
    1: Windows_NTFS George 500.1 GB disk5s1
    /dev/disk6
    0: Apple_partition_scheme *25.8 MB disk6
    1: Apple_partition_map 32.3 KB disk6s1
    2: Apple_HFS Silverlight 25.7 MB disk6s2
    edits-mac-pro:~ Edit$
  • Chris Murphy
    January 23, 2014 at 4:10 pm
    If you don’t already have a current backup of this raid0 array, do it ASAP.
    304 sectors have been reallocated by the drive firmware
    1435 sectors are pending reallocation. Some of these may not be reallocated because they can’t be read without error, and where the source of the problem is. The firmware won’t move the data if it can’t read it. So the data in these locations is already lost, effectively. There are some data recovery techniques to recover that sector despite the read error, but it’s quite tedious and in the realm of specialized data recovery.
    This is a kind of write error and there have been 78564 of them.
    I personally would have this disk replaced under warranty. To keep it for raid0 usage is asking for more trouble, corrupt files, and an untimely death of the array. For any other purpose, at a minimum I would write zeros [1] to the drive, and then run an extended smart self-test [2]. Afterwards, if current pending sectors isn’t zero, then the drive is toast.
    If this drive isn’t in warranty, I’ll gladly accept it as a donation for R&D however. 😀
    [1] I prefer booting linux and using hdparm to issue the ATA Security Erase command. It’s obscure but it’s much faster than Disk Utility write zeros, and it also zeros deallocated sectors, i.e. sectors that contain stale data but can’t be erased any other way because they no longer have an LBA due to reallocation events. Another way to do this within OS X is to use dd with a block size of 1MB, which is option bs=1m. That’s also faster than Disk Utility, but can’t erase data in remapped sectors.
    [2] smartctl -t long, this is part of the smartmontools package which can be built from Macports (using XCode). It’s not included in OS X. Macports can also build an installer package, so it’s installable on other computers without having to compile per machine.
  • Chris Murphy
    January 23, 2014 at 4:25 pm
    Looks like disk4 is the logical device created from disk0s2, disk1s2, disk2s2 as raid0. The previous error message:
    Use these commands:
    diskutil info disk0
    diskutil info disk1
    diskutil info disk2
    In one of those results you should find the UUID above, “member E7E30B03…” which will implicate a particular /dev/diskX device.
    Since /dev/diskX can change between boots, you’d want to use this command:
    system_profiler SPSerialATADataType
    That will return some more detailed information on each physical SATA disk. Look for BSD Name, and find the implicated diskX from above, and about five lines above that you’ll see the serial number for the drive producing the error.
