Activity › Forums › Adobe After Effects › Inconsistant display when I collapse trans on duplicated instances
  • Inconsistant display when I collapse trans on duplicated instances
    Posted by Mark Ivan on August 12, 2010 at 3:06 pm
    Hi there
    Having a problem recalling the answer to this problem I’m in again.
    I have 4 instances of the same precomp in my comp. The only difference between them is that I’ve shortened & offset some of the the layers to create a complex animation (large technical diagram of servers passing info to each other, etc). All the Instances have collapse transformation on as they get blurry when I size them correctly & collapsing sharpens them back up
    The comp with these 4 instances is then put into my main comp and then animated to move & scale in, but I’m getting odd motion blur on the instance in the top left for some reason, when they come to rest. It’s like its got a different shutter phase to the others and theres an odd jarring. Thing is they’re all the same precomp with the same source.
    I do see a difference in the timeline switch icons when I compare it to the others. They’re all collapsed but it’s the only one with a dash through the quality and motion blur switches but I cant see a reason for this as it is the same instance as the other 3. It hasn’t got any effects on it to make it different. Inside the instance all motion blur & max quality switches are on (none are collapsed).
    Why am I getting a different result when I collapse the top left instance, since its the same as the other 3 I have ?
    Mark Ivan replied 16 years, 1 month ago 35,075 Members · 1 Reply
  • Mark Ivan
    August 13, 2010 at 9:58 am
    Hmm, maybe I’m going into too much detail.
    Perhaps my question should be – what causes those dashes in the quality and motion blur switches when you collapse a pre-comp? Sometimes I get them, sometimes I don’t. Can’t recall/ find why.
    Yes I probably should pre-render anyhow. Thanks for that.
