Activity › Forums › AJA Video Systems › Inconsistant “A” frame in 2:3
  • Inconsistant “A” frame in 2:3
    Posted by Michael R. on December 15, 2006 at 11:29 pm
    I’m working on a feature in 1080p 23.98. The other departments want SD 29.97. No problem I think, I’ll have my Kona 3 do it quick and dirty out to tape, downconverting and adding the 2:3 at the same time.
    Everything works great, except the “A” frame isn’t the same each time. We are not using deck control. I’m simply playing out from the Final Cut Pro timeline and crash recording. Nonetheless, the first frame of picture in my sequence is the same, and I’d expect it to be the “A” frame every time. Sometimes it is. Sometimes it’s not.
    Can I get the “A” frame consistent without using deck control?
    Thanks all.
    Marcus Ionis replied 19 years, 9 months ago 2 Members · 1 Reply
  • Marcus Ionis
    December 15, 2006 at 11:47 pm
    To My Knowledge you can not get a consistant “A” Frame without out deck control. The “A” frame must always be placed on “0” “5” or “10” frame.
    Deck Control is very important in this process.
    Good Luck
    Marcus
