Activity Forums Adobe Premiere Pro inconistent output video SDI declink extreme PrPro
  • inconistent output video SDI declink extreme PrPro
    Posted by Harry Dawson on February 18, 2014 at 8:17 pm
    Sometimes it works but mostly it does not. Tried every setting possible,
    uninstalled and reinstalled BMD video desktop. It works in some sequences but not others with the same settings.
    Mac Pro 2-3.01GHz 6 core., 64RAMM
    Harry Dawson replied 12 years, 6 months ago 3 Members · 3 Replies
  • Peter Garaway
    February 19, 2014 at 12:34 am
    Hi Harry,
    Sorry to hear your having problems with your output. When you say “inconsistent output” do you mean you keep losing signal to the output monitor?
    I’ve haven’t seen this issue reported. Does this card work with other software? It sounds like it could be a connection issue ie cable, monitor or the card itself. Do you have another card you can test with?
    Peter Garaway
    Adobe
    Premiere Pro
  • Tero Ahlfors
    February 19, 2014 at 5:31 am
    Also what resolutions/framerates are you trying to run through it? For example 720p25 and 720p30 aren’t valid signals.
  • Harry Dawson
    February 25, 2014 at 1:07 am
    Sometimes it works, but mostly it does not. Also sound has to be reactivated by “settings” window in “project general”. 1080i is the selected output which worked in Final Cut, but doesn’t in PrPro.
