Incomplete tutorial?
I am trying to recreate the effects in “Peel-Away Vortex” Transition Effect Hosted by Aharon Rabinowitz.
I can create the two compositions “Text_Wipe” and “BuildUp” from the brief summary in the Tutorial, but don’t know where Aharon gets the “Form” included in the Main Composition. I can’t locate “Tutorial 21” which is mentioned in “Vortex.flv” because I can’t locate any numbering system.When I tried to load the “Vortex_Full_Project.aep” I got a message stating there were 11 references to missing effects and was asked to install the effects “Light Factory”, “Form”, “RG Shadow” and “Looks”)
I did not see what version of After Effects was being used or the platform.
I do own CS3 and CS4 (Macintosh), but I’m forced to use After Effects 7.0 (PC) at college. As I result I haven’t loaded CS4 (it clashes with CS3 currently loaded, I’d load 7.0, but I can’t get a copy).
Can someone advise where the missing components come from. I.e. are they part of CS4 or do they come from another source?
Confused
