Activity Forums Adobe Premiere Pro Incomplete srt
  • Incomplete srt
    Posted by David Cabestany on January 9, 2020 at 10:46 pm
    I’m trying to import an srt file into the timeline, but only a very small part of it comes in. I checked the timecodes and seems to be ok. Any advice would be greatly appreciated. This is a time-sensitive project.
    Thanks in advance.
    Kevin Gannon replied 5 years, 11 months ago 4 Members · 3 Replies
  • Rich Rubasch
    January 10, 2020 at 11:30 pm
    Was the SRT generated from a video whose timecode matches the clip you are trying to add it to?
    Sometimes I’ve seen a 23.976 movie was used to create the SRT and then it is applied to a 29.97 master encode.
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Greg Janza
    January 13, 2020 at 1:31 am
    SRT files import based on the settings in the caption dialogue box. Check the import settings for your captions. Reset them to default settings if they’ve been changed.
    Delete the SRT from your Premiere project and then delete the sidecar file that will be located in the same folder as your SRT at the finder level. Then re-import the SRT into Premiere.
    https://www.linkedin.com/in/tmprods
    tallmanproductions.net
  • Kevin Gannon
    October 6, 2020 at 8:17 pm
    Hi David,
    Did you ever find a solution to this? I’m running into the same issue. Rich and Greg had solid advice, but I have yet to find a solution.
    Cheers!
