Activity Forums Apple Final Cut Pro Legacy Incomplete QT export
  • Incomplete QT export
    Posted by Samah Bennett on January 4, 2008 at 11:36 pm
    I am exporting QT files from an XDCAM sequence, it took over an hour for the export of a 30 minute sequence, but the exported file only has the first 3 minutes! I checked to make sure the in and out points were correctly set and they were- this is really mystifying. Does anybody have any idea what could be causing this?
    Samah Bennett replied 18 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Jeremy Garchow
    January 5, 2008 at 8:03 pm
    Out of disk space? Where are you exporting from? Is the timeline selected when you export?
  • Bryan Dicerb
    February 12, 2008 at 10:40 pm
    I just had an issue exporting back to disc. apparently only the 1st 8 minutes exported of the 30 minute show. No errors, nothing showing why this happened. Anyone ever had this issue? I am right now re-rendering the show as a file and am going to try and put it to disc again tomorrow, but would love some sort of explanation of how this could possibly happen.
    Using flip4mac on FCP 6
  • Jeremy Garchow
    February 13, 2008 at 3:54 pm
    1) You have in and out points marked on your timeline.
    2) you are out of disc space.
  • Bryan Dicerb
    February 13, 2008 at 4:11 pm
    New just formatted disc and no in-out points set. Does Flip4Mac look at in-out points? I export via ethernet.
  • Jeremy Garchow
    February 13, 2008 at 4:17 pm
    [Bryan DiCerb] “Does Flip4Mac look at in-out points? I export via ethernet.”
    If you have in and out points set on your timeline, that’s all that gets exported. What do you mean you export via ethernet?
  • Bryan Dicerb
    February 13, 2008 at 4:29 pm
    Flip4mac exports to XDCAM via ethernet or firewire. Ethernet is a heck of a lot faster than real time.
    Well I am going to hope I had an outpoint in my timeline at the time of export and this isn’t some sort of freaky bug. All I know is I haven’t messed with it since I exported and there are no ins-outs on the timeline now.
  • Jeremy Garchow
    February 13, 2008 at 4:36 pm
    Perhaps you should check here:
    https://forums.creativecow.net/viewforum/232
  • Samah Bennett
    February 13, 2008 at 7:26 pm
    I have heard of this issue with flip4mac, but unfortunately I don’t remember the solution. I would first export a Quicktime movie, then put that on a sequence and try exporting that as a wmv. Perhaps you should look into some flip4mac forums or something like that, because I’ve heard of that problem and I know people found a solution…
