Activity Forums Sony Cameras “Incomplete” clips won’t import
  • “Incomplete” clips won’t import
    Posted by Dale Larsen on February 20, 2008 at 6:20 pm
    I have just started using a EX-1 & the XDCAM transfer software.
    I can’t import clips that are “incomplete” because they are on different cards (or folders since I had to dump several cards to a folder during a long shoot)
    XDCAM does not want to import them. I can play them in XDCAM transfer but not import.
    I also have some files with the extension SMI instead of mp4.
    no idea how or where these different extensions come from.
    HELP!
    need advise please
    Dion Hawley replied 18 years, 2 months ago 3 Members · 3 Replies
  • Sverker Hahn
    March 1, 2008 at 10:01 am
    Hi, Dale,
    I have the same problem. Have you got a solution since your post?
    Sverker Hahn, Stockholm
    Slower is better!
    EX1
    Canon XH A1
    iMac Intel
    Final Cut Studio
  • Sverker Hahn
    March 1, 2008 at 5:33 pm
    Solved it.
    Choose both folders in Transfer tool, select both clips and use the buttons in the logging pane, but I had to scroll down to the bottom to see them.
    Slower is better!
    Sony EX1
    Canon XH A1
    iMac Intel
    Final Cut Studio 2
  • Dion Hawley
    July 4, 2008 at 12:39 am
    In the transfer tool select the incomplete clip and then expand the subclips menu next to the source monitor, put a check by both clips or the master clip and then you should be able to import them. Took me two shoots to realize I was missing the footage. How is that for probably missed the money shot!!!!! Kid of feel like Sony should have some kind of automated reconnect, but who knows.
