Activity Forums Apple Final Cut Pro Legacy Incomplete Audio Renders
  • Incomplete Audio Renders
    Posted by Kevin Dinh on August 5, 2010 at 5:42 am
    When I render an imported MP3 file (44.1 kHz, which the sequence is also set to) and try to render it, it will estimate the render time to be about 10 minutes, but at 3% it stops rendering as if it was complete. However, I know it is an incomplete render because during playback, there are subtle beeps. Is there any fix to this?
    John Fishback replied 16 years, 1 month ago 3 Members · 2 Replies
  • Sam Vz
    August 5, 2010 at 2:37 pm
    And if you convert it to .AIFF using iTunes or QuickTime Player?
    Here you can learn how to prevent getting beeps: Audio problem.
    Sam van Zoest,
    Camera Operator and Editor at DeltaShock
  • John Fishback
    August 5, 2010 at 5:15 pm
    FCP wants to see audio files as Linear PCM, 48kHz, 16or 24 bit. As Sam suggests, use an external app to convert your mp3 audio to the above.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
