Activity › Forums › DVD Authoring › Incompatible Format
  • Incompatible Format
    Posted by Sam Pope on May 7, 2008 at 4:12 pm
    I need to author a DVD for a short (4 min) project that I put together. I exported the timeline to compressor and compressed it using the HD DVD: H.264 90 minutes setting at 10.3Mbps.
    When I try to import it as an asset into DVD Studio Pro it tells me that it’s an incompatible format. I know DVD Studio Pro accepts H.264…so what’s the problem? I’m supposed to deliver this DVD this afternoon, so any help would be appreciated.
    John Higgs replied 18 years, 4 months ago 3 Members · 5 Replies
  • Ryan Valle
    May 7, 2008 at 10:05 pm
    make sure your dvd studio pro project is set to HD-DVD.
    – Ryan Valle
  • Sam Pope
    May 8, 2008 at 12:30 am
    did that. still no luck. i checked the manual and hd h.264 should be compatible.
    i’d prefer to use that and not mpeg..
    thanks
  • John Higgs
    May 8, 2008 at 1:56 pm
    I import the timeline to create a quicktime movie then into Studio Pro 4 then burn the
    HV-DVD TS in Toast9 with HD Plugin onto a good quality standard DVD disc, works a treat.
  • Sam Pope
    May 8, 2008 at 3:35 pm
    Okay, but isn’t H.264 and Apple codec? Hard to figure out why it would be so hard to bring it DV SP…
  • John Higgs
    May 9, 2008 at 2:31 pm
    I had the same problem, i am waiting for a mate of mine to work it out, but as i said i did it
    in quicktime with great results.
    John Higgs.
    PS,
    I shoot on HD-Cam, and import to FCP at 10Bt uncompressed, the HD-DVDs are
    fantastic.
