Activity › Forums › Avid Media Composer › Incompatible Edit Rates
Posted by Erik Lutsch on November 29, 2011 at 10:45 pmI’m attempting to multigroup 2 cameras in a 23.98 project and I’m receiving the error “incompatible edit rates.” Has anyone encountered this issue before and have a solution?
Erik Lutsch replied 13 years, 1 month ago 6 Members · 10 Replies -
Shane Ross
November 29, 2011 at 11:28 pmDid both cameras shoot 23.98? Both have the same dimensions?
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Erik Lutsch
November 29, 2011 at 11:35 pmYes, both cameras are shot 23.98 at 1080p and this is a 23.98p 1080p project.
John Pale
November 29, 2011 at 11:52 pmWhat codec/resolution?
Any BWFs or other audio files involved?
Erik Lutsch
November 30, 2011 at 3:16 amThe codec is DNX35 1080p. There is 4 channels of audio for each cam and backup audio. Multi group does work when I only group clips that overlap each other in a sequence.
Job Ter burg
November 30, 2011 at 10:44 amIf you splice both cams into to the timeline, ungrouped, does either one of them show the green dot?
Erik Lutsch
December 1, 2011 at 4:15 pmNo, it is a brand new project and has been a 23.98 project from the start.
Erik Lutsch
December 1, 2011 at 4:19 pmAfter I receive the error, I get 40-60 multigroup clips depending on the amount of footage in the sequence. Each multigroup is a section of the sequence. It would be nice to get one multigroup sequence, but it seems like that isn’t possible.
Erik Lutsch
August 14, 2013 at 7:47 pmYes, I exported an ALE and reimported it. The metadata might have been corrupted. Reimporting an ALE file fixed it.
