Activity Forums Apple Final Cut Pro Legacy Incease Audio
  • Posted by Dennis Cummins on May 8, 2005 at 4:11 pm
    Hey wondering if anyone can help me as im in a spot of bother. Is there anyway of uping the audio in FCP3. in one of my projects the audio is really low and needs to be increased a fair bit. anyone know how i can do this?? Cheers
    Chris Poisson replied 21 years, 4 months ago 4 Members · 6 Replies
  • Thaxter Clavemarlton
    May 8, 2005 at 5:33 pm
    Add the Audio Filters > Apple > AUPeakLimiter and adjust the “Pre-gain” to any level you want.
  • Dennis Cummins
    May 8, 2005 at 6:41 pm
    cheers thax. cant seem to find it though. are you sure FCP 3 has it?
    May 8, 2005 at 7:00 pm
    [dc] “cheers thax. cant seem to find it though. are you sure FCP 3 has it? “
    Nope, sorry, its only in FCP 4x.
    But never fear, here’s how to do something similar in FCP 3:
    Add the Audio Filters > Compressor/Limiter Filter to a clip, then click that clip back into the viewer “Filters” window.
    As a starting point, adjust the Settings to an “all 2’s” formula:
    Threshold (db) -20
    Ratio 2
    Attack Time 20
    Release Time 200
    Preserve Volume CHECKED (very important!)
    Now click the viewer to display the actual audio track and set the Level to “2” or “3” (or even HIGHER it the track level is very low.
    Now, when you play the track it should be at “more consistent”, and much louder level.
    You can play with this “all 2’s” formula if you want, but its a good starting point for compressing the levels without a lot of compressor “pumping.”
    The “Threshold” setting will affect the clip the most… as you slide left, it brings more of the low levels UP.
    The actual volume adjustment now comes from the “Level” slider on the actual audio track (and you can key-frame that if you want.)
  • Matt Murray
    May 8, 2005 at 10:45 pm
    Another way to “boost” your audio is to copy the audio track and then paste it onto the tracks below.
    You can repeat this process more than once, and you will not encounter as much hiss as normally occurs when “bumping” up the volume.
    This has worked well for me on several occasions.
    Matt Murray
    Lineside Productions
    Wellington, FL
    https://www.edgesportfishing.com
    Florida Sailfish videos, pictures and more
    My World Video Productions
    Mac OS X 10.3.7 , QT 6.5 Dual 2.5 GHZ, 4 gigs RAM, 23″ HD display, JVC BR-3000 deck, 5 120 gig LaCie Firewire Drives, JVC 17″ H1700 NTSC monitor, FCP HD, DVDSP 3.02, Compressor 1.2.1, Motion 1.01
    May 8, 2005 at 11:17 pm
    [Matt Murray] “and you will not encounter as much hiss as normally occurs when “bumping” up the volume. “
    In digital, the noise-floor should not be affected whether you do this via increasing the gain or by “doubling” the tracks… as the noise ON the actual track will “double” along with the “wanted” audio, regardless.
    And I really dislike doing he “double-up” (or more) as it makes fading and level-riding more complex (as well as making a more a more cumbersome timeline.)
    With FCP4+ the “instant” PRE-GAIN makes for a very fast adjustment without the “match-frame” and multi-track hassles.
    But, thanks for mentioning this method, as it has been popular in the past.
    To each his own!
  • Chris Poisson
    May 10, 2005 at 2:55 pm
    DC,
    Peak DV which you should have has a gain adjust feature.
