Activity Forums Adobe Audition Inaudible audio
  • Inaudible audio
    Posted by Mark Withers on March 15, 2014 at 6:53 am
    Hi
    I am truly stumped….
    I have a ‘depth bomb’ sound effect that is perfectly audible on my MacPro via the external speakers. I’m using it on my Final Cut Pro timeline.
    If I mix it into the project – to say export the whole project as an MP4 (for example) it is still audible.
    HOWEVER, if I play that file on my MacBook Pro or on my television the ‘depth bomb’ sound effect disappears!
    Here is the original file, and I have not initially changed any of the bit rate or sample or frequency settings (although it is not 44 or 48Hz:
    https://www.freesound.org/people/ZeSoundResearchInc./sounds/147880/
    Type – AIFF (.aiff)
    Duration – 00:20:323
    Filesize – 6.8 MB
    Samplerate – 88200.0 Hz
    Bitdepth – 16 bit
    Channels – Stereo
    Obviously after hours of attempting to get this sound to playback I HAVE tried changing the various options of sample/bit rate (primarily 48 Hz) and frequencies, plus swapped channels, raised/lowered the bass and volume and created different audio file types – AIFF, MP3, WAV – but no joy. whatsoever.
    I’ve never come across anything like this and I approached a pro sound mixer who is also stumped. its seems the frequency is too low to be heard by all speakers, but I need to find a way to remedy that.
    Any ideas? I’d be REALLY GRATEFUL, as this project should be delivered 18th March 2014.
    Thank you in advance
    Mark
    https://bonobo-film.com
    Mark Withers replied 12 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
