Activity Forums Apple Final Cut Pro Inadequate Audio. Whats the reason?
  • Inadequate Audio. Whats the reason?
    Posted by David Powell on February 25, 2013 at 5:24 am
    What are the limitations of FCP’s sync feature for multiclips? I have had video and audio only clips that I lined up in angle editor with extremely clean audio right on top of the matching sound and I get this message after a long unsuccessful syncing. Is there a problem mixing audio with various sample rates? Are there video limitations also?
    T. Payton replied 13 years, 6 months ago 2 Members · 5 Replies
  • T. Payton
    February 25, 2013 at 2:37 pm
    [David Powell] “I get this message after a long unsuccessful syncing. “
    Can you post again. We don’t see the message.
    T. Payton
    OneCreative, Albuquerque
  • David Powell
    February 25, 2013 at 7:46 pm
    That’s strange I can see it. But here it is again:
  • T. Payton
    February 25, 2013 at 7:56 pm
    Is there a picture of an error message that you are trying to post? If so we’re not seeing it.
    If not you mentioned a message, what does the message say?
    T. Payton
  • David Powell
    February 25, 2013 at 8:31 pm
    Ooh sorry. No I don’t have a picture. That is the exact wording after the failed sync though. “inadequate audio”. fortunately it was easy to manually sync this sound file. It’s a problem though when it’s multiple video files, which happens often. I figured there was some limitation in mixing formats that I may not be aware of.
  • T. Payton
    February 25, 2013 at 10:12 pm
    I haven’t seen or heard of any audio format restrictions in FCP X. I have synced a large amount of double system sound and never had a problem.
    Are the audio/video files out of ordinary? What are they exactly?
    T. Payton
