Activity Forums Adobe After Effects Inaccurate Renders
  • Inaccurate Renders
    Posted by Carlos Angulo on February 26, 2006 at 3:55 pm
    I have a huge problem with After effects, when I do a render it doesn’t look exactly the same as when I do a Ram preview, This has happened to me before and I’ve been able to solve it by doing a Full ram preview and then saving it, but I would like why does this happens, I could send a pict so you guys can check it out.
    Thanks a lot.
    Barend Onneweer replied 20 years, 6 months ago 3 Members · 2 Replies
  • Al
    February 27, 2006 at 9:28 am
    Have you got effects on some layers that you’ve ‘eyeballed’ off rather than actually deleting? When you render, the default setting is to turn these effects back on…
  • Barend Onneweer
    February 27, 2006 at 10:39 am
    It could be anything. Are you previewing at full res? Are you doing OpenGL previews? You could always render using ‘current settings’ instead of best settings, which should use your preview settings.
    Bar3nd
    Forum COWmunity leader for:
    ADOBE AFTER EFFECTS
    MAGIC BULLET SUITE
    INDIE FILM & DOCUMENTARY
