Activity Forums Apple Final Cut Pro Legacy Inaccurate edit to tape with DVCPro50 deck
  • Inaccurate edit to tape with DVCPro50 deck
    Posted by Amund Lie on October 18, 2005 at 7:18 pm
    Hello,
    Had the deck for more than a year now, but never tried mastering back to DVCPro50 tape. It’s a Panasonic AJ-SD93E PAL deck and has been working flawlessly when loading in material into Final Cut.
    However, when doing edit to tape the deck will not do insert, neither with Firewire or RS-422 (via Keyspan). In assemble (tape has bars/black and TC) the in-point will sometimes be late by 2 frames, sometimes 5,6 or 7 frames. Occasionally the inpoint will be correct, but the first 7 frames are a freeze of the first frame of the programme. Also, over the course of the recording the programme will drift, i.e. points in the show that I know start at certain timecodes will be late by 4 – 5 frames as if the 25fps speed is not maintained.
    Can anyone explain this odd behaviour?
    Amund
    Tim Bird replied 20 years, 10 months ago 2 Members · 1 Reply
