Activity › Forums › Adobe Premiere Pro › inability to play sound file in Premier Pro
  • inability to play sound file in Premier Pro
    Posted by Jimmy D on November 30, 2005 at 10:09 am
    I have the Sony DCR-403E DVD handy cam and I want to edit the footages I shoot in Premier Pro 1.5. As far as concern the video it works fine but as far as concern the sound I just can get it work. I have tried to import the vob file directly from the disc (after finalization) but in Premier when I import it, I see two tracks (video and sound), the sound doesn’t play, can’t hear anything. The sound track is visible but there is no waveform in it as normally happens with a sound file imported in the timeline. I have tried to import the vob file using DVD decrypter first but I get the same problem. I used also the mpeg-vcr application to demultiplex the vob file and I exported it as a mpg file (video and audio). Still in premier the tracks as separated, recognized as video and audio in the timeline but no waveform is visible, no sound is heard. I have the main concept plug-in for Premier Pro 1.5 installed and I tried this in DV premier project and DVD main concept project as well. But no difference, the sound doesn’t play. Any ideas what may be the problem?
    Jimmy D replied 20 years, 10 months ago 2 Members · 2 Replies
  • Mike Velte
    November 30, 2005 at 1:14 pm
    The audio is probably Dolby and not editable.
    Best solution for editing DVD footage is to use an analog/digital converter to capture the video and audio as digital. ADS Pyro A/V Link for less than $200 will work fine.
  • Jimmy D
    December 2, 2005 at 4:16 pm
    Thanx for the info and your suggestion. I was thinking however, is there a utility that would convert my mpa audio file to wav so that it becomes editable? In windows movie maker for istance, I can import the mpa audio file and convert it nice and smoothly in wma format but unformtunately it doesn’t solve my problem as wma is the only format I can export and it clearly lacks the quality of the original mpa file.
